I am still having trouble with an issue already posted.
I am having this problem only with the Zendesk Trigger node, and i am using the 0.202.1 Version
Do you know when will be fixed?
Hi @Gabriele_Bracciali, an error of No entity column "hash" was found would suggest n8n is looking for a database column not present in your schema. Unfortunately, you seem to have deleted all the information requested in the question template here on the forum though.
Could you confirm a few more details to get a better understanding of your problem? In particular, I’d like to know
Hey @MutedJam thanks for replyng.
i am using Cloud version
After updating to the new version, there is always an error but with different text:
Please resolve outstanding issues before you activate it
i was having only 1 tab open
4.nope
Hi @Gabriele_Bracciali, I am so sorry for that. Would new workflows using the Zendesk trigger also be affected? As in, if you create a completely new workflow, add a fresh Zendesk trigger (not copying an existing one), are you able to activate your workflow?
And can you double-check the credentials you have in use?
Yes also if i create a new workflow and using a new Zendesk trigger.
I am using a webhook trigger for replace it until it will be fix.
What you mean with credentials?
Hi @Gabriele_Bracciali, I meant your Zendesk credentials configured in n8n as invalid credentials are a typical cause for an error such as “Please resolve outstanding issues before you activate it”.
That said, I was able to reproduce the problem in the meantime and shall add this to our engineering backlog for a closer look. We’ll confirm once this has been fixed.
The zendesk credential are ok
i will wait,
Thanks for your help!
Hi all, activating workflows including the Zendesk trigger should work again with n8n v0.204.0. Just make sure to actually define a condition in the trigger node, otherwise you’d see an “Unkown error”:
I’ve had this issue now once too. Not the Zendesk node but simple webhook.
As I have suggested in one other topic.
Moving a node and re-saving the workflow works to fix the issue. Just make sure to deactivate the workflow first.
I got this error today and it was a strange issue which I chalked off to a “one off” glitch.
I opened an existing and working workflow starting with a webhook trigger - changed the name and tried to save it and got this hash error.
Couldnt figure out what was going on.
Reloaded the page and I see two new nodes in there just on their own - not sure where they came from!
Deleted those two - saved and all worked well.
