No SFTP connection available USING SFTP Node
<Error details
Other info
n8n version
1.86.1 (Cloud)
Stack trace
Error: end: No SFTP connection available at fmtError (/usr/local/lib/node_modules/n8n/node_modules/ssh2-sftp-client/src/utils.js:55:18) at haveConnection (/usr/local/lib/node_modules/n8n/node_modules/ssh2-sftp-client/src/utils.js:319:20) at /usr/local/lib/node_modules/n8n/node_modules/ssh2-sftp-client/src/index.js:1226:11 at new Promise () at SftpClient.end (/usr/local/lib/node_modules/n8n/node_modules/ssh2-sftp-client/src/index.js:1217:12) at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Ftp/Ftp.node.js:756:20) at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:681:27) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:913:51 at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:1246:20
FTP
Parameters
Settings
Docs
Credential to connect with
Operation
Path
Recursive
I wish this node would…
Problem in node ‘FTP‘
FTP | n8n Docs
Documentation for the FTP node in n8n, a workflow automation platform. Includes guidance on usage, and links to examples.
n
All the n8n ip whitelisting is done on SFTP and required ports are open. Same SFTP we are able to connect with all other applications. While creating Credentials Private key and Passphrase is automatically filling.
Hey @ilangovan.swamy hope all is well.
Could you tell us more about your setup. I see you are using cloud version of n8n. It is rather old (1.86.1 is well behind the latest).
What about your sftp server? Where is it connecting? A specific product or just a system you own? Is own system - is it windows or linux? Please tell us more.
sftp hosted in azure Windows VM and yes , we are able to connect sftp from every ware els except from N8N ftp Node, even we have allowed all given on Cloud IP addresses | n8n Docs
I am ok to connect on call .
Documentation for n8n, a workflow automation platform.
Please take a look at the following topic:
There I have investigated the issue with a similar problem, where the outcome happened to be that the module used by n8n to connect to another server with ftp over ssh (sftp) fails due to the compatibility problem between the (third party) module and Windows servers.
New version [email protected] got released which includes the GitHub PR 27210.
