Nod launch - Best AI to use that is part of my current stack, or not super slow to respond
Hey friends! I am very excited to use Nod today and get setup - I checked out some issues with Support and they advised I check here with all you experts! I use n8n as the foundation for all of my Bots, Routines, etc. So I am excited to check this out - I tried today but am having some issues.
My Claude Premium plan doesn’t connect - and I need an API key and credits.
I am trying Gemini free version but it’s super slow. 14 mins to reply to first question.
I have ChatGPT but it’s only standard.
Does anyone have any ideas? #n8n #nod #claude #aiagents #n8n #nod #claude #aiagents #nocode #buildinpublic | Emer McArthur - be great to connect with like minded n8n’ers!
No error as such - but the turnaround time for reply was 14 mins using Gemini
This is how it answered
Hey @Emer_McArthur, while you wait for a response, here are some things that might help:
Suggested resources
Docs:
Forum:
@Anshul_Namdev, @mohamed3nan - you’ve helped with similar issues before, can you take a look?
Hast du
gelesen?
Auch hier:
You need the right tool for the right job.
I believe n8n assistant can do it.
You do not need nod, the shiny new toy
Hi @Emer_McArthur, I’d stick with Gemini for the next test. Under Settings > Models, check whether you’re using Gemini 3.8 Flash. It has a free API tier. The Claude error in your screenshot is about the Anthropic API credit balance, which is billed separately from your Claude subscription.
Fourteen minutes is a long wait for a first reply. Your screenshot shows Nod had queued a follow-up while it was still working. Once it’s idle, could you send just “Reply with the word hello” and see how long the first reply takes? If that also takes minutes, use Send feedback in Nod and include the model name and elapsed time. You can review the diagnostic report before sending it.
And yes, Nod can build n8n workflows for you. Open Apps, connect n8n, then ask it to build a specific workflow. It’ll leave you a draft to review.
Thank you both! I said hello and got - I couldn’t finish this. The model provider’s quota was reached (HTTP 429). Try again later. If it keeps happening, check the provider account’s usage limits and billing.
@Emer_McArthur, that 429 means the request hit a provider quota. If you’re still using Gemini, open https://aistudio.google.com/rate-limit and select the project your Nod API key belongs to. Check the limits for the model selected in Nod.
If you’ve used the daily request allowance, it resets at midnight Pacific time. A per-minute limit needs a short pause before retrying.
Which model is selected in Nod, and which limit shows as reached in AI Studio?
