Node credentials and custom information and configuration erased every 30 minutes or so
Title. Further information:
  1. Every 30 minutes or so the credentials from any flow that I’m working on are erased from the workflow.
  2. Also every custom configuration like cURL code are also erased.
Needless to say that this completly brakes my workflows and keep me even from sharing with the community (since I cannot publish broken workflows).
  • n8n version: 1.82.3
  • Database (default: SQLite): Default
  • Operating system: MacOS Sequoia 15.1
Is there a chance you have the same workflow open in a different browser tab/window?
Maybe try to upgrade n8n on your account.
Thank you so much, simply upgrading and restarting n8n worked
