Running n8n on Docker Synology. I am probably asking very basic question but could find an answer. I like to extract value from $node and using the following expression in SET string value
{{$node[“Email Parser Snippet”].json[“Guest name”]}}
The issue is that when I run the workflow the output is “{{$node[“Email Parser Snippet”].json[“Guest name”]}}” rather than the actual value. seems like the function is set as string value instead of pulling the info and replacing the value.
Please share the workflow
(Select the nodes and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow respectively)
“nodes”: [
“parameters”: {
“keepOnlySet”: true,
“values”: {
“string”: [
“name”: “Property”,
“value”: “Test”
“name”: “Full Name”,
“value”: “{{$node["Email Parser Snippet"].json["Guest name"]}}”
“name”: “Phone Number”,
“value”: “{{$node["Email Parser Snippet"].json["Phone"]}}”
“name”: “Check In Date”,
“value”: “{{$node["Email Parser Snippet"].json["Check-in"]}}”
“name”: “Confirmation Code”,
“value”: “{{$node["Email Parser Snippet"].json["Confirmation Code"]}}”
“number”: [
“name”: “Nights”
“name”: “Guests”
“options”: {}
“name”: “Set”,
“type”: “n8n-nodes-base.set”,
“typeVersion”: 1,
“position”: [
420,
440
“connections”: {}
