Hey, how are you doing?
I’ve created a custom node. I want some properties of this node to have default expression.
Right now when defining a property I did this:
displayName: “Type”,
type: “string”,
default: “{{$node[“Webhook”].json[“body”][“type”]}}”
And then in execute function I use “evaluateExpression” function and everything works well, but this node looks like this:
But I need a way to implement this behaviour like this:
This one evaluate the expression before execute. The property has an expression and you can remove it as well. (It’s not a string just like the first one)
Is there any way for doing this ?
