Notion weird issue
Hey!
Notion made some changes on their API what broke notion node.
More info
Discord discussion
Node work and say that resurned n items but it does not return them
Screenshot
How to reproduce
I made special database for this purpose on notion:
Use the following token: redacted (just in case)
And following node options:
Thanks!
Hey @Shirobachi, thank you so much for providing this example case! I’ve already added this to our backlog and we’ll keep you posted.
For the time being you might want to consider downgrading to n8n@0.192.2 which seemed to work fine for me.
This should now be fixed with n8n@0.193.3 @Shirobachi. Sorry for the trouble and once again thank you so much for your help!
