I had two workflows which were both working then after 30 November 2025 stopped. The error is "Client authentication failed (e.g., unknown client, no client authentication included, or unsupported authentication method).
The first pushes data to an Excel 365 file in my OneDrive, the second emails notification using Outlook. Below is the Excel node as an example - the problem appears to be the same for both. NB I have replaced anything that looks like an ID or key with [RemovedForSecurity].
The AI help suggests that I need to use Azure platform to create a secret, however there doesn't appear to be anywhere to add that in n8n
"Client authentication failed (e.g., unknown client, no client authentication included, or unsupported authentication method"
workflow to push data to Excel 365:
There is no ouput from the node
- n8n version: - Have updated to n8n@2.0.3, but problem persists.
- Database (default: SQLite):
- Running n8n via n8n cloud: starter plan
- Operating system:
I’m not a programmer, so the OAuth2 stuff is beyond my knowledge - can anyone help with what I should do to get my workflow working again?
Thanks in advance.
