Ollama embedding does not accept the model, but using it with http request works
First, closely related to Error with ollama embedding model but a bit different
When I set up the ollama embedding node, it will not “accept” the model I have loaded for embedding, but when I generate the query using http request node it work and returns a good reply with the vectors.
Update for some reason it suddenly accepted the model, so I tested, but still not working.
Error in sub-node ‘Embeddings Ollama1‘
model " nomic-embed-text:latest" not found, try pulling it first
Not much of a workflow yet. Building out my moving parts like queries before going to more complex stuff. Just the isolated ollama embed node failing and the http request node working.
and
http://host.docker.internal:11434/api/embedding
Headers:
  "Content-Type": "application/json",
  "Accept": "*/*",
  "User-Agent": "python-requests/2.32.3"
Body (JSON):
  "model": "nomic-embed-text:latest",
  "input": "This is the text I want to embed"
The node won’t accept the model, so cannot even test
  • n8n version: 1.70.3
  • n8n EXECUTIONS_PROCESS setting (default: own, main): No idea
  • Operating system: Win11 host, Ubuntu WSL to create containers
Welcome to the community @lamachine !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
See if you can follow this guide showing how the model could be easily added, https://www.youtube.com/watch?v=XQ7wNqbB1x8 (you can start from the 8th minute). This is a genaral tutorial on using LLM with n8n and could answer other questions you might have.
Son of a gun, that was what I needed. There was never a drop down list. I added a couple more models, then clicked back to my flow then into my ollama embedding, and there it was. Thank you so much.
