The idea is:
The Ability to Import a JSON Schema to the “Edit Fields (Set)” Component
My use case:
I have a lengthy JSON field which needs to receive data from many components, and I would rather use the “manual fields” than JSON mapping, for easy mapping rather than using JS notation for us no-coders.
<> JSON vs Manual Mapping <>
The need to create a ton of fields manually & consistent data entry. Simply copy/paste a JSON schema which creates the fields for me. This is quite similar to the CURL Import for the HTTP Component.
Solving;
- Easy Mapping for lengthy JSON data
- Consistent Data structures throughout workflows
The Ideal is similar to https://www.make.com/en/help/tools/json which essentially allows you to define and store data structures in your instance for easy consistent usage, and allowing you to define that by copy/pasting JSON
Don’t have the capability to, but I would!
