I use a Outlook node to read e-mail. I get the body as HTML, would it be possible to get it as text?
Hey @msn,
Welcome to the community ![]()
I can’t see a setting for it but maybe the extract html node can be used to the data you want?
As i see the Microsoft Graph has an option to get the body as text instead of HTML. But how to set that in n8n?
Hey @msn,
We don’t have an option that I can see in the node, I have changed this to a feature request so in the future we can look at making this happen. As a workaround it could be worth looking at extracting the text using other nodes or if you wanted to get really fancy and have some time our code is available on Github so you could pop open a PR and add in an option to get as text ![]()
