Parsing HTTP node data to input to LLM
Hello, I have a workflow where I am making an API call to an authentication system to collect system logs. The response comes back with application/json and I want to be able to take this as an input to an LLM for further analysis. For example I converted the application/json input to a json body like this
What can i do to further extract this data to feed information the LLM to analyze it? Any suggestions are welcome.
Below are the details.
Hey @Ashish_Bhatia You can put up a Edit Node to collect the required files and pass it to the agent node.
Are you stuck somewhere?
Thanks I resolved this by using edit node,
Hey @Ashish_Bhatia Please mark it as solution
