Permettre au node Guardrails de ressortir l’input complet
Hello,
I would like to propose an improvement to the Guardrails node, based on a very concrete use case in an existing workflow.
Current issue
Today, when the Guardrails node detects a violation (e.g. secretKeys, PII, etc.), it does not return the original input as-is.
As a result:
  • The output is fragmented (checks, detectedSecrets, flags, etc.)
  • The initial input (text, JSON, enriched content) is no longer directly usable
  • Integrating Guardrails into an already-in-production workflow becomes painful, sometimes even blocking
In real-world workflows, Guardrails is usually an intermediate validation node, not a terminal one.
Not being able to easily retrieve the input prevents:
  • Clean conditional routing (pass / fail)
  • Reuse of the validated content
  • Compatibility with existing chains (LLM → Guardrails → post-processing)
Expected behavior
Ideally, the Guardrails node should offer at least one of the following options:
  • Return the original input as-is
    e.g. output.originalInput
  • Optional “pass-through” mode
    • No violation → output = input + metadata
    • Violation → output = input + violations
  • Simple toggle
    • Include original input in output
This would make it possible to:
  • Insert Guardrails without breaking existing workflows
  • Avoid workaround nodes (unnecessary Set / Merge nodes)
  • Keep Guardrails as a true control/validation node, not a dead end
Why this matters
In complex workflows (especially involving LLMs, CMS, RAG, or automated publishing), Guardrails needs to be:
  • Non-destructive
  • Transparent
  • Easily chainable
Today, its behavior forces users to manually rebuild what already existed in the input.
