Pin data is not working properly with split node
Hello!
I’ve found that pin data is not correctly pins it while using inside the Split node. It pins only last execution of a node. So other executions are completely ignored
Please share the workflow
expected output:
actual:
issue with:
  • n8n version: 0.190.0
Hi @barn4k, many thanks for reporting this and for sharing your example workflow. I am so sorry for the trouble this causes.
I’ll add this to our internal bug tracker and we’ll confirm once this has been fixed.
