Hello,
I’m the new user on the n8n. i want to create workflow n8n with kibana. What i want to do, the n8n workflow will check the kibana daily and check the logs if there is any error or any issue will send me daily notification email by outlook. Also, will check the which server mostly active and used. Like morning email notifications. Does anyone have any idea. how can I do that?
The kibana is opensource and I have a n8n is up and running.
