Possible errors when working with n8n tools
License & Activation Errors
“The activation key has already been used in this instance”
“License verification failed”
“Invalid or expired license key”
“Cannot reach license se
rver
so the issue here is that you’re seeing license activation errors in n8n. these can be tricky!
first, make sure you’re entering the key correctly, sometimes extra spaces or characters sneak in when copying from an email - try typing it directly [github.com]('Activation failed' when entering an activation key · Issue #21654 · n8n-io/n8n · GitHub). if you’ve migrated your n8n instance, the key might be tied to a previous installation, so you may need to reach out to n8n support to reset the activation status [community.n8n.io](Activation Key Error After Migration Between Platforms).
License & Activation Errors – Real Solutions
Common errors covered
“Cannot reach license server”
A. “The activation key has already been used in this instance”
Why this really happens
The license is stored in /home/node/.n8n
You:
rebuilt or recreated the container
restored a backup
changed Docker volumes
ran two containers pointing to the same .n8n directory
n8n thinks it’s the same instance trying to re-activate
What actually fixes it
Stop all n8n containers
Copy code
docker ps
docker stop <container_id>
Make sure only ONE container uses the volume Check:
Copy code
docker inspect <container_id>
Look for /home/node/.n8n
Restart the container without changing the volume The license should auto-validate
If it still fails
Contact n8n support
Ask for a license reset
They do reset keys — this is normal
B. “License verification failed” / “Cannot reach license server”
Server has no internet access
Firewall blocks outbound HTTPS
Corporate proxy blocks license call
Incorrect system time
Verify outbound HTTPS From inside container:
Copy code
curl https://license.n8n.io
Check firewall / proxy
Allow outbound port 443
Configure proxy variables if needed:
Copy code
HTTPS_PROXY
HTTP_PROXY
Check system time
Wrong clock = SSL failure
Sync time on host machine
C. “Invalid or expired license key”
Typo while pasting key
License already revoked
License expired
Using Enterprise key on wrong edition
Copy & paste the key again (no spaces)
Confirm license type matches n8n edition
Check expiry date in the license email
Contact n8n if unsure — they’ll confirm status
D. License breaks after Docker rebuild or migration
.n8n folder was not persisted
Volume path changed
New container ID created
Always persist:
Copy code
/home/node/.n8n
Use bind mounts, not anonymous volumes
Avoid running multiple environments with the same license
If already broken → request reset from n8n
E. Best practices to avoid license issues
One license = one instance
One .n8n volume per environment
Don’t share volumes across containers
Backup .n8n before upgrades
Stop old containers before starting new ones
Hey @Cybercode3 Have you checked your Usage & Plans inside the settings? If you are registered it would show something like this:
Please let me know if you dont see that ‘Registered’ tag. Hope this helps!
You:
restored a backup
Copy code
docker ps
Copy code
If it still fails
Contact n8n support
Copy code
Copy code
HTTPS_PROXY
HTTP_PROXY
Check system time
License expired
Volume path changed
Always persist:
Copy code
/home/node/.n8n
