Problem in node "Qdrant vector store" unauthorized
When I try to insert documents into vector store i am receiving “Problem in node Qdrant vector store”. But I am receiving "Connection tested successfully " in credentials with the API key
  • *n8n version:1.72.1
  • *Database :postgre sql
  • *Running n8n via (Docker, npm, n8n cloud, desktop app):docker
  • *Operating system:windows
Hi @Kanchana_Pathirage
Thanks for posting here and welcome to the community! :cake:
Could you please try updating to 1.75 and test your credentials again?
HI, thanks, deleting the api key and adding it back helped to solve.
