i have a problem in using the node 'Read/write Files from disk
The file was created but its identity does not match and cannot be written.///
“errorMessage”: “The file was created but its identity does not match and cannot be written.”,
“errorDetails”: {
“rawErrorMessage”: [
“n8nDetails”: {
“nodeName”: “Read/Write Files from Disk”,
“nodeType”: “n8n-nodes-base.readWriteFile”,
“nodeVersion”: 1.1,
“operation”: “write”,
“itemIndex”: 0,
“time”: “2/10/2026, 6:36:49 PM”,
“n8nVersion”: “2.6.3 (Self Hosted)”,
“stackTrace”: [
“NodeApiError: The file was created but its identity does not match and cannot be written.”,
" at ExecuteContext.execute (C:\Users\hichr\AppData\Local\nvm\v22.12.0\node_modules\n8n\node_modules\n8n-nodes-base\nodes\Files\ReadWriteFile\actions\write.operation.ts:130:10)“,
" at ExecuteContext.execute (C:\Users\hichr\AppData\Local\nvm\v22.12.0\node_modules\n8n\node_modules\n8n-nodes-base\nodes\Files\ReadWriteFile\ReadWriteFile.node.ts:69:17)”,
" at WorkflowExecute.executeNode (C:\Users\hichr\AppData\Local\nvm\v22.12.0\node_modules\n8n\node_modules\n8n-core\src\execution-engine\workflow-execute.ts:1069:8)“,
" at WorkflowExecute.runNode (C:\Users\hichr\AppData\Local\nvm\v22.12.0\node_modules\n8n\node_modules\n8n-core\src\execution-engine\workflow-execute.ts:1250:11)”,
" at C:\Users\hichr\AppData\Local\nvm\v22.12.0\node_modules\n8n\node_modules\n8n-core\src\execution-engine\workflow-execute.ts:1685:27",
" at C:\Users\hichr\AppData\Local\nvm\v22.12.0\node_modules\n8n\node_modules\n8n-core\src\execution-engine\workflow-execute.ts:2328:11"
