hi, I download n8n from git and since today I get error
the commands:
git clone --branch [email protected]
npm install --global [email protected]
git reset --hard
git clean -dfx
npm I
lerna bootstrap --hoist
npm run build
I am using node 14.17.4
I upgrade to node to v16.16.0 and this fix the problem
Glad to hear you figured it out!
Also, just as a heads up, we moved away from from lerna and npm in newer versions: How to run in laptop the new version of n8n (0.203.0)? - #2 by jan
thanks for the info
