Problem with google sheet
Hi
i dont understant the problem. its worked well until this morning
no when it read google sheet it still block on the nodes.
its running, but on editor and manual, i just see node google sheet running even if its finish.
my server is contabo, and i use a docker n8n on coolify. I test with a second dcontainer and same.
i test on local and its words perfectly !
But i change nothing on my server or coolify.
My server have enough cpu and memory
What i have to check ?
Debug info
core
  • n8nVersion: 1.56.2
  • nodeJsVersion: 20.15.0
  • database: postgres
  • executionMode: regular
  • concurrency: -1
  • license: community
  • consumerId: unknown
storage
  • success: all
  • error: all
  • progress: false
  • manual: true
  • binaryMode: memory
pruning
  • enabled: true
  • maxAge: 336 hours
  • maxCount: 10000 executions
Generated at: 2024-08-29T12:02:16.891Z
Hi @nusquama, could you share your workflow by pasting the JSON in between two block quotes (```)?
thank you, but it was a server problem !
