Hi,
I have this situation:
- set node
- http request node
- if node
In if node I compare 2 value number:
the first number is taken from query parameter.
the second number from input data.
When the value of query parameter is static value (0), it’s all ok.
But when the value is a given by expression ({{$json[“next_offset”]}}), if return false when it should come back true.
next offset is output of set node and its value is 0
What am I doing wrong?
