Problem with Medium node
I am using the Medium node to post articles to the Medium.com platform, and it worked fine for several months. Two weeks ago suddenly the node is stopping to work in 4 different workflows for 4 different Medium accounts, and all stopped at the same time. No change in the workflows, credentials or Medium accounts.
ERROR: Forbidden - perhaps check your credentials?
Just a moment… Enable JavaScript and cookies to continue (function(){ window._cf_chl_opt={ cvId: ‘2’, cZone: ‘api.medium.com’, cType: ‘non-interactive’, cNounce: ‘60099’, cRay: ‘7ce6a00b0e541e55’, cHash: ‘723892e39887f28’, … and some more javascript code.
  • n8n version: 0.224.4
  • n8n EXECUTIONS_PROCESS setting (default: own, main): queue
  • Operating system: Debian
Hey @Martin_Neumann
That is interesting it looks like rather than using the API it is trying to do something else. I will check if the api has changed tomorrow.
Hey @Martin_Neumann,
It doesn’t look like the API has changed, Are you still seeing the same issue and could you share teh full output?
Are you also posting as a user or as part of a publication?
Hm, I can’t activate workflows with Jotform nodes in them :sweat_smile:
## Workflow could not be activated:
*Just a moment... Enable JavaScript and cookies to continue (function(){ window._cf_chl_opt={ cvId: '2', cZone: 'eu-api.jotform.com', cType: 'managed', cNounce: '28807', cRay: '7d29f3d5bc6718fd', cHash: 'eb356022fb9799c', cUPMDTk: "\/form\/231016600816041\/webhooks?__cf_chl_tk=_pClfu6IjYHCff05gwm.liJ8XoFf0Kreo8EnevSIawA-1685984223-0-gaNycGzNDLs", cFPWv: 'g', cTTimeMs: '1000', cMTimeMs: '0', cTplV: 5, cTplB: 'cf', cK: "", cRq:
.history.replaceState(null, null, ogU); }; } document.getElementsByTagName('head')[0].appendChild(cpo); }());
  • n8n version: n8nio/n8n:latest
  • Operating system: Ubuntu 23.04
Hey @organicnz,
Can you open a new thread for that one? Medium and Jotform are different services so it could be that the errors are unrelated… Another option could be that they are both using something Cloudflare and the 2 installs here are on Digital Ocean and the IPs have been added to a ban list.
Hey @Jon,
Thank you very much for your reply :slight_smile:
Opps, apologies about it. Already opened a new thread:
