Problem with passing date to IF node to compare dates
I am getting dates (in my case in seconds) and want to use it as a rule in the IF node to compare this date with the current date
It seems that the Date & Time rule requires a type of Date but n8n provides only String
“nodes”: [
“parameters”: {},
“typeVersion”: 1,
“position”: [
0,
0
“id”: “10b1cbaa-a6c8-49e4-81c1-e84e197b21e3”,
“name”: “When clicking ‘Test workflow’”
“parameters”: {
“operation”: “search”,
“subreddit”: “smallbusiness”,
“keyword”: “looking for a solution”,
“limit”: 10,
“additionalFields”: {
“sort”: “hot”
“type”: “n8n-nodes-base.reddit”,
“typeVersion”: 1,
“position”: [
220,
0
“id”: “3a72ae03-1059-4aba-8ef9-60e9833026e1”,
“name”: “Reddit”,
“credentials”: {
“redditOAuth2Api”: {
“id”: “5XSMHWMXzAeNGU9E”,
“name”: “Reddit account”
“parameters”: {
“conditions”: {
“options”: {
“caseSensitive”: true,
“leftValue”: “”,
“typeValidation”: “strict”,
“version”: 2
“conditions”: [
“id”: “1b3b0724-3f56-45d1-a02a-26213469121d”,
“leftValue”: “={{ $json.ups }}”,
“rightValue”: 2,
“operator”: {
“type”: “number”,
“operation”: “gt”
“id”: “04b8663f-df03-44dc-985a-3e4f6a3f9e22”,
“leftValue”: “={{ $json.selftext }}”,
“rightValue”: “”,
“operator”: {
“type”: “string”,
“operation”: “notEmpty”,
“singleValue”: true
“id”: “fd9d2c48-1f04-442b-a320-bb5d3c74d881”,
“leftValue”: “={{ DateTime.fromSeconds($json.created).toISO() }}”,
“rightValue”: “”,
“operator”: {
“type”: “dateTime”,
“operation”: “afterOrEquals”
“combinator”: “and”
“options”: {}
“type”: “n8n-nodes-base.if”,
“typeVersion”: 2.2,
“position”: [
420,
0
“id”: “45e805f3-cfb0-49bd-953f-1246a5296743”,
“name”: “If”
“connections”: {
“When clicking ‘Test workflow’”: {
“main”: [
“node”: “Reddit”,
“type”: “main”,
“index”: 0
“Reddit”: {
“main”: [
“node”: “If”,
“type”: “main”,
“index”: 0
“pinData”: {},
“meta”: {
“instanceId”: “79a77c65395341caf2dc425c59f08c775489ad1be2e0de03ea9045c9a2cd127a”
  • n8n version: 1.79.3
  • Database (default: SQLite): N/A
  • Operating system: MacOS
Hey @Dariusz_Mozgowoj try to not use toIso() as it converts to a string and creating the error.
{{ DateTime.fromSeconds($json.created) }}
It is still not Date but string, I have tried this. I manage to do this around using middle step of other node. However I believe it is highly inconvenient that this node is working now different now.
Can you post your workflow with some example data in a code block so that it will be properly rendered?
type or paste code here
