Problem with the n8n database
Some nodes are returning an error, from what I can tell only in HTTP requests, and based on the error, it seems to be something in the n8n database itself. They even appeared in different flows.
“errorMessage”: “column 9827483463398fbb7d6b96916fe451d8bdefa0e8.role does not exist”,
“errorDetails”: {},
“n8nDetails”: {
“n8nVersion”: “1.112.5 (Self Hosted)”,
“binaryDataMode”: “default”,
“stackTrace”: [
“QueryFailedError: column 9827483463398fbb7d6b96916fe451d8bdefa0e8.role does not exist”,
" at PostgresQueryRunner.query (/usr/local/lib/node_modules/n8n/node_modules/@n8n/typeorm/driver/postgres/PostgresQueryRunner.js:219:19)“,
" at processTicksAndRejections (node:internal/process/task_queues:95:5)”,
" at SelectQueryBuilder.loadRawResults (/usr/local/lib/node_modules/n8n/node_modules/@n8n/typeorm/query-builder/SelectQueryBuilder.js:2192:25)“,
" at SelectQueryBuilder.getRawMany (/usr/local/lib/node_modules/n8n/node_modules/@n8n/typeorm/query-builder/SelectQueryBuilder.js:646:29)”,
" at SelectQueryBuilder.executeEntitiesAndRawResults (/usr/local/lib/node_modules/n8n/node_modules/@n8n/typeorm/query-builder/SelectQueryBuilder.js:1979:26)“,
" at SelectQueryBuilder.getRawAndEntities (/usr/local/lib/node_modules/n8n/node_modules/@n8n/typeorm/query-builder/SelectQueryBuilder.js:684:29)”,
" at SelectQueryBuilder.getOne (/usr/local/lib/node_modules/n8n/node_modules/@n8n/typeorm/query-builder/SelectQueryBuilder.js:711:25)“,
" at refreshFn (/usr/local/lib/node_modules/n8n/dist/credentials-helper.js:236:36)”,
" at CacheService.get (/usr/local/lib/node_modules/n8n/dist/services/cache/cache.service.js:166:34)“,
" at CredentialsHelper.credentialCanUseExternalSecrets (/usr/local/lib/node_modules/n8n/dist/credentials-helper.js:234:18)”
  • n8n version: 1.112.5 [Self Hosted]
  • Database (default: SQLite): postgresql
  • n8n EXECUTIONS_PROCESS setting (default: own, main): EXECUTIONS_MODE=queue
It appears the role column is missing from the Postgres DB. Are you running in scaling mode? If yes, you need to make sure they are on the same version as the main n8n instance and re-deploy them. Also check this thread:
Also dropping this for reference if the previous one doesn’t help:
Yes it’s running in scaling mode. I just redeployed everything and that fixed it, thank you so much :folded_hands: :folded_hands:
