Problem with Webflow API Access
yes, but the webhook is working now!
But what is the problem now with webflow :frowning:
ahh glad that it worked. So if that works you should not have issues with Webflow.
loading …
Because you are using localhost for testing. To test a trigger, you need to run n8n with a tunnel.
I am not using localhost, n8n is hosted on my server and domain:)
The picture that you sent me (check below) says localhost. If that is what you see in your server. Then, you need to manually set the env variable WEBHOOK_TUNNEL_URL=yourdomain/
okay, now the url is the domain, but its loading more than 1minute :slight_smile:
Did you forget the https:// part?
like this?
Yes, try the webflow trigger now
No, same problem :joy:
Shit :frowning:
