I have the attached workflow that I am having issues with. Everything works as expected until it gets to the final Spotify step which is to add the songs that match the IF statements to the specified playlist “Dance”. There should be 12 matching songs from this weeks Discover Weekly playlist but it only adds the first one for some reason. I thought it was only adding one in testing but I let the workflow trigger at its normal time this morning and the same thing occurred. Any insight would be greatly appreciated.
"name": "Spotify Archive Discover Weekly",
"nodes": [
"parameters": {},
"name": "Start",
"typeVersion": 1,
"position": [
140,
110
"disabled": true
"parameters": {
"resource": "playlist",
"operation": "getUserPlaylists",
"returnAll": true
"name": "Get Playlists",
"type": "n8n-nodes-base.spotify",
"position": [
250,
-160
"executeOnce": false,
"typeVersion": 1,
"retryOnFail": true,
"maxTries": 5,
"credentials": {
"spotifyOAuth2Api": "Colin"
"parameters": {
"operation": "getTracks",
"id": "={{$node[\"Find Weekly Playlist\"].json[\"uri\"]}}",
"returnAll": true
"name": "Get Tracks",
"position": [
870,
340
"executeOnce": true,
"typeVersion": 1,
"alwaysOutputData": false,
"maxTries": 5,
"credentials": {
"parameters": {
"id": "={{$item(0).$node[\"Find Archive Playlist\"].json[\"uri\"]}}",
"trackID": "={{$json[\"track\"][\"uri\"]}}"
"name": "Save to Archive",
"position": [
1020,
500
"typeVersion": 1,
"maxTries": 5,
"credentials": {
"parameters": {
"conditions": {
"string": [
"value1": "={{$json[\"name\"]}}",
"value2": "Discover Weekly Archive"
"name": "Find Archive Playlist",
"type": "n8n-nodes-base.if",
"position": [
510,
30
"typeVersion": 1,
"maxTries": 5
"parameters": {
"triggerTimes": {
"item": [
"mode": "everyWeek",
"hour": 10
"name": "Cron",
"type": "n8n-nodes-base.cron",
"position": [
-220,
-160
"notesInFlow": false,
"typeVersion": 1
"parameters": {
"conditions": {
"string": [
"value2": "Discover Weekly"
"name": "Find Weekly Playlist",
"position": [
500,
240
"typeVersion": 1,
"maxTries": 5
"parameters": {
"mode": "wait"
"name": "Merge",
"type": "n8n-nodes-base.merge",
"position": [
720,
340
"typeVersion": 1,
"maxTries": 5
"parameters": {
"authentication": "oAuth2",
"operation": "append",
"sheetId": "1_YMgIP_f8XKOc9wl7djtRtEmLicyzik1oqBL4P4uNug",
"range": "A:M",
"options": {}
"name": "Google Sheets",
"type": "n8n-nodes-base.googleSheets",
"typeVersion": 1,
"position": [
2050,
590
"maxTries": 5,
"credentials": {
"googleSheetsOAuth2Api": "Colin"
"parameters": {
"values": {
"string": [
"name": "Song",
"value": "={{$node[\"Get Tracks\"].json[\"track\"][\"name\"]}}"
"name": "Artist",
"value": "={{$node[\"Get Tracks\"].json[\"track\"][\"artists\"][0][\"name\"]}}"
"name": "Dancability",
"value": "={{$json[\"danceability\"]}}"
"name": "Energy",
"value": "={{$json[\"energy\"]}}"
"name": "Tempo",
"value": "={{$json[\"tempo\"]}}"
"name": "Acoustic",
"value": "={{$json[\"acousticness\"]}}"
"name": "Instrumental",
"value": "={{$json[\"instrumentalness\"]}}"
"name": "Liveness",
"value": "={{$json[\"liveness\"]}}"
"name": "Loudness",
"value": "={{$json[\"loudness\"]}}"
"name": "Valance",
"value": "={{$json[\"valence\"]}}"
"name": "Track ID",
"value": "={{$json[\"id\"]}}"
"number": []
"options": {}
"name": "Set",
"type": "n8n-nodes-base.set",
"typeVersion": 1,
"position": [
1220,
370
"maxTries": 5
"parameters": {
"resource": "track",
"operation": "getAudioFeatures",
"id": "={{$json[\"track\"][\"id\"]}}"
"name": "Spotify",
"typeVersion": 1,
"position": [
1020,
190
"maxTries": 5,
"credentials": {
"parameters": {
"url": "=https://api.spotify.com/v1/search?q={{$node[\"Get Tracks\"].json[\"track\"][\"artists\"][0][\"name\"]}}&limit=1&type=artist",
"options": {}
"name": "Get Artist Details",
"typeVersion": 1,
"position": [
1340,
600
"maxTries": 5,
"credentials": {
"oAuth2Api": "Colin-Spotify"
"parameters": {
"mode": "mergeByIndex"
"name": "Merge1",
"typeVersion": 1,
"position": [
1650,
590
"alwaysOutputData": true,
"maxTries": 5
"parameters": {
"values": {
"string": [
"name": "Song",
"name": "Artist",
"name": "Energy",
"name": "Tempo",
"name": "Acoustic",
"name": "Liveness",
"name": "Loudness",
"name": "Valance",
"name": "Track ID",
"name": "Genre",
"value": "={{$node[\"Merge1\"].json[\"artists\"][\"items\"][0][\"genres\"]}}"
"number": []
"options": {}
"name": "Set2",
"typeVersion": 1,
"position": [
1860,
590
"maxTries": 5
"parameters": {
"conditions": {
"string": [
"operation": "contains",
"value2": "Dance"
"name": "Find Dance Playlist",
"position": [
1450,
-180
"typeVersion": 1,
"maxTries": 5
"parameters": {
"id": "={{$node[\"Playlist\"].json[\"Playlist\"]}}",
"trackID": "={{$node[\"Track\"].json[\"Track\"]}}"
"name": "Spotify1",
"typeVersion": 1,
"position": [
2290,
-70
"credentials": {
"parameters": {
"conditions": {
"number": [
"value1": "={{$node[\"Spotify\"].json[\"danceability\"]}}",
"operation": "largerEqual",
"value2": 0.75
"string": []
"name": "Dancibility",
"typeVersion": 1,
"position": [
1220,
20
"parameters": {
"conditions": {
"number": [
"value1": "={{$json[\"tempo\"]}}",
"value2": 100
"name": "Tempo",
"typeVersion": 1,
"position": [
1450,
30
"parameters": {
"mode": "wait"
"name": "Merge2",
"typeVersion": 1,
"position": [
1960,
-80
"parameters": {
"values": {
"string": [
"name": "=Track",
"value": "={{$json[\"uri\"]}}"
"options": {}
"name": "Track",
"typeVersion": 1,
"position": [
1730,
30
"parameters": {
"values": {
"string": [
"name": "=Playlist",
"options": {}
"name": "Playlist",
"typeVersion": 1,
"position": [
1730,
-180
"connections": {
"Cron": {
"main": [
"node": "Get Playlists",
"type": "main",
"index": 0
"Merge": {
"main": [
"node": "Get Tracks",
"type": "main",
"index": 0
"Get Tracks": {
"main": [
"node": "Save to Archive",
"type": "main",
"index": 0
"node": "Spotify",
"type": "main",
"index": 0
"Get Playlists": {
"main": [
"node": "Find Archive Playlist",
"type": "main",
"index": 0
"node": "Find Weekly Playlist",
"type": "main",
"index": 0
"node": "Find Dance Playlist",
"type": "main",
"index": 0
"Find Weekly Playlist": {
"main": [
"node": "Merge",
"type": "main",
"index": 1
"Find Archive Playlist": {
"main": [
"node": "Merge",
"type": "main",
"index": 0
"Spotify": {
"main": [
"node": "Dancibility",
"type": "main",
"index": 0
"node": "Set",
"type": "main",
"index": 0
"Set": {
"main": [
"node": "Get Artist Details",
"type": "main",
"index": 0
"node": "Merge1",
"type": "main",
"index": 0
"Get Artist Details": {
"main": [
"node": "Merge1",
"type": "main",
"index": 1
"Merge1": {
"main": [
"node": "Set2",
"type": "main",
"index": 0
"Set2": {
"main": [
"node": "Google Sheets",
"type": "main",
"index": 0
"Find Dance Playlist": {
"main": [
"node": "Playlist",
"type": "main",
"index": 0
"Dancibility": {
"main": [
"node": "Tempo",
"type": "main",
"index": 0
"Tempo": {
"main": [
"node": "Track",
"type": "main",
"index": 0
"Playlist": {
"main": [
"node": "Merge2",
"type": "main",
"index": 0
"Track": {
"main": [
"node": "Merge2",
"type": "main",
"index": 1
"Merge2": {
"main": [
"node": "Spotify1",
"type": "main",
"index": 0
"active": true,
"settings": {},
"id": "5"
