I’m using a lot of webhooks and sometimes the N8N crashes, because of that I would like to test the queue mode to see if it will solve the problem.
already read the documentation Configuring queue mode - n8n Documentation
and I tried using a github config example n8n/docker/compose/withPostgresAndRedis at master · st-ax/n8n · GitHub
But unfortunately it didn’t work, the N8N even opens, but it’s unstable, when trying to save a workflow or something like that, an error 502 appears
I’m going to share all the configuration I’m doing from scratch and I ask for your help in case I’m missing something or if I did something wrong.
sudo apt update
sudo apt install apt-transport-https ca-certificates curl software-properties-common -y
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu focal stable"
sudo curl -L "https://github.com/docker/compose/releases/download/1.29.2/docker-compose-$(uname -s)-$(uname -m)" -o /usr/local/bin/docker-compose
sudo chmod +x /usr/local/bin/docker-compose
.docker-compose.yml
version: '3'
services:
traefik:
image: "traefik"
restart: always
command:
- "--api=true"
- "--api.insecure=true"
- "--providers.docker=true"
- "--providers.docker.exposedbydefault=false"
- "--entrypoints.web.address=:80"
- "--entrypoints.web.http.redirections.entryPoint.to=websecure"
- "--entrypoints.web.http.redirections.entrypoint.scheme=https"
- "--entrypoints.websecure.address=:443"
- "--certificatesresolvers.mytlschallenge.acme.tlschallenge=true"
- "--certificatesresolvers.mytlschallenge.acme.email=${SSL_EMAIL}"
- "--certificatesresolvers.mytlschallenge.acme.storage=/letsencrypt/acme.json"
ports:
- "80:80"
- "443:443"
volumes:
- ${DATA_FOLDER}/letsencrypt:/letsencrypt
- /var/run/docker.sock:/var/run/docker.sock:ro
postgres:
image: postgres
restart: always
environment:
- POSTGRES_USER
- POSTGRES_PASSWORD
- POSTGRES_DB
- POSTGRES_NON_ROOT_USER
- POSTGRES_NON_ROOT_PASSWORD
volumes:
- ./init-data.sh:/docker-entrypoint-initdb.d/init-data.sh
redis:
image: redis
restart: always
command: redis-server --requirepass oqSxRwNyOJXZh94nB92OVvo7Z0D
ports:
- 6379:6379
volumes:
- ./redis-data:/var/lib/redis
- ./redis.conf:/usr/local/etc/redis/redis.conf
environment:
- REDIS_REPLICATION_MODE=master
n8n:
image: n8nio/n8n
restart: always
ports:
- "127.0.0.1:5678:5678"
labels:
- traefik.enable=true
- traefik.http.routers.n8n.rule=Host(`${SUBDOMAIN}.${DOMAIN_NAME}`)
- traefik.http.routers.n8n.tls=true
- traefik.http.routers.n8n.entrypoints=web,websecure
- traefik.http.routers.n8n.tls.certresolver=mytlschallenge
- traefik.http.middlewares.n8n.headers.SSLRedirect=true
- traefik.http.middlewares.n8n.headers.STSSeconds=315360000
- traefik.http.middlewares.n8n.headers.browserXSSFilter=true
- traefik.http.middlewares.n8n.headers.contentTypeNosniff=true
- traefik.http.middlewares.n8n.headers.forceSTSHeader=true
- traefik.http.middlewares.n8n.headers.SSLHost=${DOMAIN_NAME}
- traefik.http.middlewares.n8n.headers.STSIncludeSubdomains=true
- traefik.http.middlewares.n8n.headers.STSPreload=true
environment:
- DB_TYPE=postgresdb
- DB_POSTGRESDB_HOST=postgres
- DB_POSTGRESDB_PORT=5432
- DB_POSTGRESDB_DATABASE=${POSTGRES_DB}
- DB_POSTGRESDB_USER=${POSTGRES_NON_ROOT_USER}
- DB_POSTGRESDB_PASSWORD=${POSTGRES_NON_ROOT_PASSWORD}
- N8N_BASIC_AUTH_ACTIVE=true
- N8N_BASIC_AUTH_USER
- N8N_BASIC_AUTH_PASSWORD
- N8N_HOST=${SUBDOMAIN}.${DOMAIN_NAME}
- N8N_PORT=5678
- N8N_PROTOCOL=https
- N8N_ENCRYPTION_KEY=uKCbpQ3cFxltXyhidigoyHlNhZJ0b56M5YLYl1uxuKJT
- EXECUTIONS_MODE=queue
- QUEUE_BULL_REDIS_HOST=redis
# - QUEUE_BULL_REDIS_PORT=6379
- WEBHOOK_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}/
- GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
depends_on:
- postgres
- redis
volumes:
- ${DATA_FOLDER}/.n8n:/home/node/.n8n
# Wait 5 seconds to start n8n to make sure that PostgreSQL is ready
# when n8n tries to connect to it
command: /bin/sh -c "sleep 5; n8n start"
n8n-queue:
image: n8nio/n8n
restart: always
environment:
- NODE_FUNCTION_ALLOW_BUILTIN=*
- NODE_FUNCTION_ALLOW_EXTERNAL=*
- N8N_LOG_LEVEL=debug # error, warning, info, verbose, debug
cpus: 3
ports:
- 5679:5678
depends_on:
- postgres
- redis
- n8n
volumes:
- ~/.n8n:/home/node/.n8n
command: /bin/sh -c "n8n worker"
n8n-wh:
image: n8nio/n8n
restart: always
environment:
cpus: 3
ports:
- 5680:5678
networks:
- default
depends_on:
- postgres
- redis
- n8n
- n8n-queue
volumes:
command: /bin/sh -c "n8n webhook"
.ENV
POSTGRES_USER=changeUser
POSTGRES_PASSWORD=changePassword
POSTGRES_DB=n8n
POSTGRES_NON_ROOT_USER=changeUser
POSTGRES_NON_ROOT_PASSWORD=changePassword
N8N_BASIC_AUTH_USER=changeUser
N8N_BASIC_AUTH_PASSWORD=changePassword
DATA_FOLDER=/root/n8n/
DOMAIN_NAME=example.com
SUBDOMAIN=n8n
N8N_BASIC_AUTH_USER=user
N8N_BASIC_AUTH_PASSWORD=password
GENERIC_TIMEZONE=Europe/Berlin
[email protected]
init-data.sh
#!/bin/bash
set -e;
if [ -n "${POSTGRES_NON_ROOT_USER:-}" ] && [ -n "${POSTGRES_NON_ROOT_PASSWORD:-}" ]; then
psql -v ON_ERROR_STOP=1 --username "$POSTGRES_USER" --dbname "$POSTGRES_DB" <<-EOSQL
CREATE USER ${POSTGRES_NON_ROOT_USER} WITH PASSWORD '${POSTGRES_NON_ROOT_PASSWORD}';
GRANT ALL PRIVILEGES ON DATABASE ${POSTGRES_DB} TO ${POSTGRES_NON_ROOT_USER};
EOSQL
else
echo "SETUP INFO: No Environment variables given!"
fi
mkdir /root/n8n/
sudo docker-compose up -d
sudo docker-compose stop
if there is any other configuration that works and can help me I would be very grateful
