Help with queue mode
Hi guys, can anyone help me identify why the n8 is not working in queue mode?
Editor
Webhook
Worker
I use a new Unraid server
I have a tunnel with cloudflare. But I have already released the links that I will use on n8n.
n8n.mysite.com.br
n8nwebhook.mysite.com.br
n8n works in normal mode, only in queue mode, I don’t understand why everything went up, the account is active, but it doesn’t open either through the local IP or through the website.
192.168.10.254:5678
n8n.mysite.com.br
Values ​​that will be in the variables
N8N_EDITOR_BASE_URL = https://n8n.mysite.com.br/
WEBHOOK_URL = https://n8nwebhook.mysite.com.br/
N8N_HOST = 192.168.10.254
I tried too
N8N_HOST = https://n8n.mysite.com.br/
Editor
version: "3.8"
services:
  n8n_editor:
    image: n8nio/n8n:latest
    hostname: "{{.Service.Name}}.{{.Task.Slot}}"
    command: start
    networks:
      - bdrtec
    environment:
      - N8N_ENCRYPTION_KEY=mypass
      - NODE_ENV=production
      - N8N_METRICS=true
      - N8N_DIAGNOSTICS_ENABLED=false
      - N8N_PAYLOAD_SIZE_MAX=16
      - N8N_LOG_LEVEL=info
      - GENERIC_TIMEZONE=America/Sao_Paulo
      - N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
      - DB_TYPE=postgresdb
      - DB_POSTGRESDB_DATABASE=n8n_queue
      - DB_POSTGRESDB_HOST=postgres
      - DB_POSTGRESDB_PORT=5432
      - DB_POSTGRESDB_USER=postgres
      - DB_POSTGRESDB_PASSWORD=mypasswd
      - N8N_PORT=5678
      - N8N_HOST=n8n.mysite.com.br
      - N8N_EDITOR_BASE_URL=https://n8n.mysite.com.br/
      - N8N_PROTOCOL=https
      - WEBHOOK_URL=https://n8nwebhook.mysite.com.br/
      - N8N_ENDPOINT_WEBHOOK=webhook
      - EXECUTIONS_MODE=queue
      - QUEUE_BULL_REDIS_HOST=redis
      - QUEUE_BULL_REDIS_PORT=6379
      - QUEUE_BULL_REDIS_DB=3
      - QUEUE_BULL_REDIS_PASSWORD=
      - EXECUTIONS_TIMEOUT=3600
      - EXECUTIONS_TIMEOUT_MAX=7200
      - N8N_VERSION_NOTIFICATIONS_ENABLED=true
      - N8N_PUBLIC_API_SWAGGERUI_DISABLED=false
      - N8N_TEMPLATES_ENABLED=true
      - N8N_ONBOARDING_FLOW_DISABLED=true
      - N8N_WORKFLOW_TAGS_DISABLED=false
      - N8N_HIDE_USAGE_PAGE=false
      - EXECUTIONS_DATA_PRUNE=true
      - EXECUTIONS_DATA_MAX_AGE=336
      - EXECUTIONS_DATA_PRUNE_HARD_DELETE_INTERVAL=15
      - EXECUTIONS_DATA_PRUNE_SOFT_DELETE_INTERVAL=60
      - EXECUTIONS_DATA_PRUNE_MAX_COUNT=10000
      - EXECUTIONS_DATA_SAVE_ON_ERROR=all
      - EXECUTIONS_DATA_SAVE_ON_SUCCESS=all
      - EXECUTIONS_DATA_SAVE_ON_PROGRESS=true
      - EXECUTIONS_DATA_SAVE_MANUAL_EXECUTIONS=true
      - NODE_FUNCTION_ALLOW_BUILTIN=*
      - NODE_FUNCTION_ALLOW_EXTERNAL=moment,lodash
      - N8N_COMMUNITY_PACKAGES_ENABLED=true
      - N8N_REINSTALL_MISSING_PACKAGES=true
      #- TUNNEL_SUBDOMAIN=https://n8n.mysite.com.br/
      - N8N_SECURE_COOKIE=false
    deploy:
      mode: replicated
      replicas: 1
      placement:
        constraints:
          - node.role == manager
      resources:
        limits:
          cpus: "1"
          memory: 1024M
      update_config:
        parallelism: 1
        delay: 30s
        order: start-first
        failure_action: rollback
networks:
  bdrtec:
    external: true
Webhook
version: "3.8"
services:
  n8n_webhook:
    image: n8nio/n8n:1.78.1
    command: webhook
    networks:
      - bdrtec
    environment:
      - N8N_METRICS=true
      - N8N_PORT=5678
    deploy:
      mode: replicated
      replicas: 2
      placement:
        constraints:
      resources:
        limits:
          cpus: "1"
          memory: 1024M
      update_config:
        parallelism: 1
        delay: 30s
        order: start-first
networks:
  bdrtec:
    external: true
Worker
version: "3.8"
services:
  n8n_webhook:
    command: webhook
    networks:
      - bdrtec
    environment:
      - N8N_METRICS=true
      - N8N_PORT=5678
    deploy:
      mode: replicated
      replicas: 2
      placement:
        constraints:
      resources:
        limits:
          cpus: "1"
          memory: 1024M
      update_config:
        parallelism: 1
        delay: 30s
        order: start-first
networks:
  bdrtec:
    external: true
The problem is that I don’t use traefik, so I removed everything related to it.
I use nginx with webUI, and I’ve already configured the domains, because I have other dockers working fine via nginx
Without seeing the exact config’s its hard to say for sure, I see there is an n8n instance turned off ( not sure if it is part of it ) also do you have it connected to your redis and postgres, as I don’t think it will work without the shared database or a way to connect
Last week I did play around with getting this working, I will give you a link to my docker enviroment ( With all passwords removed, and domains removed ext… )
tholum/example-n8n-cluster
I updated the first post with all stacks.
Postgres and Redis working and connected because I use them in other applications.
To install n8n in a row you need to install it three times (Editor, Webhook, Worker)
The other installation called n8n (fourth) is the one I currently use installed in normal mode, but it is turned off.
I found help on another forum and solved it like this.
#version: '3.8'
services:
  n8n_editor:
    command: start
    ports:
      - "5678:5678"
    networks:
      - bdrtec
    environment:
      - N8N_METRICS=true
      - N8N_PORT=5678
      - N8N_HOST=192.168.1.1
      - N8N_EDITOR_BASE_URL=https://n8n.site.com.br/
      - WEBHOOK_URL=https://n8nwebhook.site.com.br/
      - N8N_AI_ENABLED=false
      - N8N_AI_PROVIDER=openai
      - N8N_AI_OPENAI_API_KEY=
      - N8N_EMAIL_MODE=smtp
      - N8N_SMTP_HOST=smtp.gmail.com
      - N8N_SMTP_PORT=465
      - N8N_SMTP_USER=mail@gmail.com
      - N8N_SMTP_PASS=
      - N8N_SMTP_SENDER=mail@gmail.com
      - N8N_SMTP_SSL=true
    deploy:
      mode: replicated
      replicas: 1
      placement:
        constraints:
      update_config:
        parallelism: 1
        delay: 30s
        order: start-first
  n8n_webhook:
    command: webhook
    ports:
      - "5677:5678"
    networks:
      - bdrtec
    environment:
      - N8N_METRICS=true
      - N8N_PORT=5678
      - N8N_SMTP_PORT=465
      - N8N_SMTP_PASS=
      - N8N_SMTP_SSL=true
    deploy:
      mode: replicated
      replicas: 1
      placement:
        constraints:
      update_config:
        parallelism: 1
        delay: 30s
        order: start-first
  n8n_worker:
    command: worker --concurrency=20
    networks:
      - bdrtec
    environment:
      - N8N_METRICS=true
      - N8N_PORT=5678
      - N8N_SMTP_PORT=465
      - N8N_SMTP_PASS=
      - N8N_SMTP_SSL=true
      - EXECUTIONS_DATA_PRUNE_SOFT_DELETE_INTERVAL=60   deploy:
      mode: replicated
      replicas: 1
      placement:
        constraints:
      update_config:
        parallelism: 1
        delay: 30s
        order: start-first
networks:
  bdrtec:
    external: true
