The n8n public API should use tags as an OR instead of an AND so setting ?tags=tag1,tag2 would return workflows that contain either tag1 or tag2 not worklfows that contain both tag1 and tag2
My use case:
I would like to filter workflows based on groups of tags using the API
Expanding on the notion of doing “both”, it would also be useful to consider argument parsing support for:
sub-grouping - so logical AND/OR/NOT combinations wouldn’t be limited to just first-to-last precedence
quoted values - so that special characters like commas or logical operator terms could be distinguished from characters/keywords that happen to be embedded in the actual tag-value text.
Examples: (not URL encoded for easier reading)
tags= ((‘project1’ OR ‘project2’) AND ‘Q2-release’)
tags=‘Question AND Answer Automation’ OR ‘Errors,Omissions’
Maybe part of what I’m expressing here is that opening this can-of-worms probably asks for a common mini-DSL logical-expression-parser library to deal with the same issue on more than just the workflow tags argument. I could imagine the same library sitting underneath a “Complex Filter” node in n8n (similar to the flat/linear “Filter” node that currently exists, but with logical sub-groups).
