Hello everyone,
Please help me. I am experiencing an issue with the Python code node runner. I tried using the docs task runner setting for setup, but when I try to run the Python code on my n8n, clicking on ‘Execute Code’ simply loads for a long time. I also tried to follow a youtube tutorial for setting task runner on my Docker n8n client, but it still loads. No error is showing.
I have added my configuration codes that are used to host my Docker n8n client.
This is the tutorial video - https://youtu.be/-kd5YCzAcP8?si=cWavJAZnJrmOcxI0
My Docker Compose file
### YML
services:
n8n:
image: n8nio/n8n
restart: always
container_name: n8n-server
ports:
- "5678:5678"
- "5679:5679"
environment:
WEBHOOK_URL:
N8N_RUNNERS_ENABLE: "true"
N8N_RUNNERS_MODE: "external"
N8N_RUNNERS_DISABLED_MODES: "embedded"
N8N_RUNNERS_JAVASCRIPT_ENABLED: "true"
N8N_RUNNERS_PYTHON_ENABLED: "true"
N8N_NATIVE_PYTHON_RUNNER: "true"
N8N_RUNNERS_BROKER_LISTEN_ADDRESS: "0.0.0.0"
N8N_RUNNERS_BROKER_PORT: "5679"
N8N_RUNNERS_AUTH_TOKEN: "helloworld"
env_file:
- .env
volumes:
- ./n8n-data:/home/node/.n8n
runner:
image: custom-n8n-runner
build:
context: .
dockerfile: Dockerfile
environment:
N8N_RUNNERS_TASK_BROKER_URI: "http://n8n:5679"
N8N_RUNNERS_LAUNCHER_LOG_LEVEL: "debug"
restart: always
depends_on:
- n8n
volumes:
n8n_data:
My dockerfile
FROM n8nio/runners
USER root
RUN cd /opt/runners/task-runner-python && uv pip install --python .venv/bin/python yt-dlp requests
COPY n8n-task-runners.json /etc/n8n-task-runners.json
USER runners
My JSON file
"task-runners": [
"runner-type": "javascript",
"workdir": "/home/runner",
"command": "/usr/local/bin/node",
"args": [
"--disallow-code-generation-from-strings",
"--disable-proto=delete",
"/opt/runners/task-runner-javascript/dist/start.js"
"health-check-server-port": "5681",
"allowed-env": [
"PATH",
"GENERIC_TIMEZONE",
"NODE_OPTIONS",
"N8N_RUNNERS_AUTO_SHUTDOWN_TIMEOUT",
"N8N_RUNNERS_TASK_TIMEOUT",
"N8N_RUNNERS_MAX_CONCURRENCY",
"N8N_SENTRY_DSN",
"N8N_VERSION",
"ENVIRONMENT",
"DEPLOYMENT_NAME",
"HOME"
"env-overrides": {
"NODE_FUNCTION_ALLOW_BUILTIN": "*",
"NODE_FUNCTION_ALLOW_EXTERNAL": "*",
"N8N_RUNNERS_HEALTH_CHECK_SERVER_HOST": "0.0.0.0:
"runner-type": "python",
"command": "/opt/runners/task-runner-python/.venv/bin/python",
"args": ["-m","src.main"],
"health-check-server-port": "5682",
"allowed-env": [
"PATH",
"PYTHONPATH",
"N8N_RUNNERS_LAUNCHER_LOG_LEVEL",
"N8N_SENTRY_DSN",
"N8N_VERSION",
"ENVIRONMENT",
"DEPLOYMENT_NAME",
"N8N_RUNNERS_STDLIB_ALLOW",
"N8N_RUNNERS_EXTERNAL_ALLOW"
"env-overrides": {
"PYTHONPATH": "/opt/runners/task-runner-python/",
"N8N_RUNNERS_STDLIB_ALLOW":"*",
"N8N_RUNNERS_EXTERNAL_ALLOW":"yt-dlp,requests"
- n8n version: 2.1.4
- Database (default: SQLite): default
- n8n EXECUTIONS_PROCESS setting (default: own, main): main
- Operating system: Debian 13
