Can not run Python Code Nodes in n8n 2.0. It seams n8n and Task Runners do not comunicate
I did not find an oficial compose.yaml to run n8n 2.0.0 plus TaskRunners plus Postgres plus Redis plus Caddy. With the help of AI tried several fixes for the problem. My Code Node in Pythoncontains only a return for JASON, it is the second node of 2. When it starts, keeps running but do not finish. It seams n8n and the TaskRunners do not communicate.
Please share your current docker compose with us to receive help.
This documentation was written before v2 released, but it is about the external mode, which became mandatory for V2:
Thank you very much !
I used the exact compose.yaml file from documentation you referenced.
Executed: same problem as always:
  • Code in Python (Beta) - ok
  • Code in Python (Native)(Beta) - code block does not end
Changed n8n to image “n8nio/n8n:2.0.0”
Same problem:
This is the log:
8n-main | Task request timed out after 60 seconds
n8n-main | Task request timed out
n8n-main | Error: Task request timed out
n8n-main | at ErrorReporter.wrap (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/errors/error-reporter.ts:242:37)
n8n-main | at ErrorReporter.error (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/errors/error-reporter.ts:228:25)
n8n-main | at LocalTaskRequester.requestExpired (/usr/local/lib/node_modules/n8n/src/task-runners/task-managers/task-requester.ts:309:22)
n8n-main | at LocalTaskRequester.onMessage (/usr/local/lib/node_modules/n8n/src/task-runners/task-managers/task-requester.ts:272:10)
n8n-main | at TaskBroker.handleRequestTimeout (/usr/local/lib/node_modules/n8n/src/task-runners/task-broker/task-broker.service.ts:115:50)
n8n-main | at Timeout. (/usr/local/lib/node_modules/n8n/src/task-runners/task-broker/task-broker.service.ts:102:9)
n8n-main | at listOnTimeout (node:internal/timers:588:17)
n8n-main | at processTimers (node:internal/timers:523:7)
n8n-main |
n8n-main | Task request timed out after 60 seconds
This is the compose file:
services:
n8n:
#image: n8nio/n8n:1.111.0
image: n8nio/n8n:2.0.0
container_name: n8n-main
environment:
  - N8N_RUNNERS_ENABLED=true
  - N8N_RUNNERS_MODE=external
  - N8N_RUNNERS_BROKER_LISTEN_ADDRESS=0.0.0.0
  - N8N_RUNNERS_AUTH_TOKEN="abcde"
  - N8N_NATIVE_PYTHON_RUNNER=true
ports:
  - "5678:5678"
volumes:
  - n8n_data:/home/node/.n8n
# etc.
task-runners:
image: n8nio/runners:1.111.0
container_name: n8n-runners
environment:
etc.
depends_on:
  • n8n
volumes:
n8n_data:
