Python runner unavailable in n8n (Python 3 is missing from this system) – Docker / Alpine container
<!-Hello everyone,
I am running n8n on a VPS (Ubuntu 24.04). n8n is running inside a Docker container, and it appears to be Alpine-based.
I am having an issue with the Python node. When I try to execute it, I receive the following error:
Python runner unavailable: Python 3 is missing from this system
I have already installed Python 3 on the root system of my VPS, and I can run it manually from the server without any problem. However, n8n does not detect it, and the Python node still does not work.
From what I understand, the n8n container environment is isolated, and it seems Python is not installed inside the container itself. Since the container is Alpine-based, I am not sure what is the correct and recommended way to enable Python support.
My questions:
What is the proper way to enable Python inside the official n8n Docker container?
Do I need to create a custom Docker image that includes Python?
Is there any recommended guide or video tutorial that explains how to properly configure this setup?
I would really appreciate any guidance or documentation that can help me solve this issue.
Thank you in advance.- Hey! The fastest way to find solutions is by using the :magnifying_glass_tilted_right: search function at the upper right.
If your question hasn’t been asked before, please follow the template below. Skip the questions that are not relevant to you. →
Hi! This is a common issue when running n8n in the official Docker image, which is Alpine-based and does not include Python by default.
You have two main options:
Option 1: Create a custom Dockerfile (recommended)
Create a Dockerfile that extends the official n8n image and installs Python:
FROM n8nio/n8n:latest
USER root
RUN apk add --no-cache python3 py3-pip
USER node
Then build and run your custom image:
docker build -t n8n-python .
docker run -it --rm -p 5678:5678 n8n-python
Option 2: Use docker-compose with an init command
If you use docker-compose, you can add a command to install Python on startup (less ideal but works for testing):
services:
  n8n:
    image: n8nio/n8n
    user: root
    command: >
      sh -c "apk add --no-cache python3 py3-pip && su node -s /bin/sh -c 'n8n'"
Important notes:
  • Make sure you use python3 and pip3 in your Code nodes, as the Alpine package is python3, not python
  • The N8N_RUNNERS_ENABLED=true environment variable may be needed for the Python task runner in newer versions
  • For production, Option 1 (custom Dockerfile) is always the better approach
Hope this helps!
Hi @MOHAMMED_ABDALELAH_M
Welcome to the n8n community :tada:
You are installing the dependency in the wrong place. You need to create a custom image based on the official n8n image and install Python using apk. Creating a custom Docker image is the correct approach and considered best practice in this scenario.
The n8n documentation explains how to build a custom image here: Docker | n8n Docs
Unfortunately, there is no official n8n image that comes with Python preinstalled.
Hi,
the apk package manager has been removed from the official n8n Docker images. However, you can find a solution to copy it from Alpine Linux in the following community thread:
