Virtual environment is missing error while running Code in Python node with the internal task runner
I’ve seen similar topics but I haven’t figured it out yet so I’ll leave my case here.
I’m trying to build and run Docker image based on the official image in order to install Python in it to use Code in Python node with the task runner internal mode.
Now I successfully installed Python in the image with the Dockerfile below, but when I run the container, I get error message below.
How do I use Code in Python node in n8n 2.7.4 with the task runner internal mode?
The reason for the choice of internal mode is because it’s intended to deploy to a VM in our private network, so the ease of use is more prioritized than security and performance.
I tried manually creating .venv inside /home/node and set N8N_PYTHON_BINARY and PATH etc, but this didn’t work either.
venv module is installed by default and it can correctly create virtual environment.
I’ve seen some comment here is saying that new n8n is supposed to create its own virtual environment so that I don’t have to write docker instructions or something, but I don’t see any virtual environment created by n8n inside the container when I check inside.
Dockerfile
FROM n8nio/n8n:latest
# Switch to root to install packages
USER root
# Install apk
RUN wget https://gitlab.alpinelinux.org/api/v4/projects/5/packages/generic/v2.14.4/x86_64/apk.static
RUN chmod +x apk.static && \
    ./apk.static -X http://dl-cdn.alpinelinux.org/alpine/v3.22/main -U --allow-untrusted --initdb add apk-tools
# Install Python and required build tools
RUN apk add --update --no-cache python3 py3-pip py3-setuptools py3-wheel
# Set Task Runners internal model
ENV N8N_RUNNERS_MODE=internal
# Switch back to node
USER node
Error message
n8n-1  | Failed to start Python task runner in internal mode. because its virtual environment is missing from this system. Launching a Python runner in internal mode is intended only for debugging and is not recommended for production. Users are encouraged to deploy in external mode. See: https://docs.n8n.io/hosting/configuration/task-runners/#setting-up-external-mode
  • n8n version: 2.7.4
  • Running n8n via (Docker, npm, n8n cloud, desktop app): Docker, self-hosted
  • Operating system: Ubuntu 24
Hi @teddy8193
The supported way to use the Python Code node in n8n v2.7.4 is to:
  • Enable runners and set them to external in the n8n container:
environment:
  - N8N_RUNNERS_ENABLED=true
  - N8N_RUNNERS_MODE=external
  - N8N_RUNNERS_BROKER_LISTEN_ADDRESS=0.0.0.0
  - N8N_RUNNERS_AUTH_TOKEN=your-secret-here
  - N8N_NATIVE_PYTHON_RUNNER=true
  • Run a sidecar container with the matching n8nio/runners image and the same auth token, as shown in the docs: [External mode]
task-runners:
  image: n8nio/runners:2.7.4   # version must match n8nio/n8n
  environment:
    - N8N_RUNNERS_TASK_BROKER_URI=http://n8n-main:5679
  depends_on:
    - n8n
If you need extra Python packages, you have to extend the n8nio/runners image, install them there, and allowlist them via n8n-task-runners.json, not to modify the main n8nio/n8n container: [Adding dependencies]
Hope this will help you!
Based on my research, I now have a clear picture. The internal mode for Python expects n8n to manage its own venv at a specific path inside the @n8n/task-runner-python package, but the official Docker image doesn’t ship with the Python task runner package — it’s only in the separate n8nio/runners image. So internal mode with Python basically doesn’t work properly from the base n8n image. The real solution is external mode with the runners sidecar container.
Here’s my reply:
Internal mode for the Python runner doesn’t really work with the base n8nio/n8n image, the error you’re seeing is because the @n8n/task-runner-python package (which includes its own managed .venv) only ships in the separate n8nio/runners image. Just installing Python into the main container isn’t enough since n8n expects that whole task runner package with its venv already set up at a specific path. Your best bet is to switch to external mode and run the n8nio/runners container as a sidecar, it’s honestly not much more complicated and it actually works. Set N8N_RUNNERS_MODE=external, N8N_RUNNERS_ENABLED=true, and N8N_RUNNERS_AUTH_TOKEN on the n8n container, then spin up the runners container with the matching token pointed at your broker URI.
Hi! I had the exact same issue when tried to deploy n8n on render and managed to solve it after some deep debugging.
The Root Cause:
The problem is that the official n8n Docker image (specifically around v2.7.x and v2.8.3) is actually missing the source code for the @n8n/task-runner-python package in the node_modules directory. Since the source code isn’t there, n8n cannot automatically create the .venv it needs for the internal mode, no matter how you install Python in your Dockerfile.
Basically, n8n is trying to run a script that simply doesn’t exist in the official image.
Fixed: self hosted n8n v2.8.3 Python Task Runner on Render.com
I’ve reverse-engineered the issues and found a way to “patch” the image by manually injecting the missing source code from n8n’s GitHub repository and setting up the environment correctly.
If you want a deployment that works out of the box with Python (and includes pandas/requests), I’ve shared the instructions and a one-click deploy button here:
https://github.com/api29200/n8n_v2.8.3-render-python
It fixes the permission errors, restores the missing environment files, and handles the virtual environment creation that n8n expects. Even if you are not using Render, you can check my Dockerfile in that repo to see how to properly restore the missing runner files to your own image.
