Question about using wait nodes
So, I’ve been toying a bit with the wait node, and searching a bit on how to make workflows more “asynchronous”, and came across the following post : Wait Node Delays Node in Different Connection from Executing
While I know that that is expected behaviour and why, would it be possible to have a workaround to the result the poster wanted, so as to, for example, have one “path” executed and at one point having a wait node waiting for a callback, while another path would go on and be executed?
  • n8n version: 1.36.1
  • n8n EXECUTIONS_PROCESS setting (default: own, main): own, main
hello @Carrico
n8n does not execute nodes asynchronously. They all executed in an order. That order depends on the n8n version though.
For your task, you should split the workflow into smaller ones and execute sub-workflows one after another with the option “Wait for sub-Workflows completion” turned off.
