Queue Controls (workflow settings and global)
The idea is:
Users need more control over queuing of jobs.
  1. add ability to set a queue limit in workflow settings
  2. add ability to set a global queue limit
  3. automatically purge queued jobs per-workflow for inactive (deactivated) workflows
  4. add ability to manually purge per-workflow job queue (queued jobs)
  5. add ability to manually purge global job queue (queued jobs)
My use case:
I have a backlog of jobs that queue indefinitely at the rate-of-schedule per workflow. This can create a massive backlog of queued jobs if the workers cannot keep up.
  1. Limiting the number of queued jobs per workflow would prevent limitless queuing.
  2. Having the ability to purge existing queues (globally and per-workflow) would restore a clean state to the queuing mechanism.
  3. Deactivated jobs should no longer have queued jobs - it’s counter-intuitive as it stands, but open to debate - either way, it should be configurable.
