Queue mode not working
I have an n8n ECS instance running on AWS + redis with auto-scale
Yesterday I had some issues with localhost, but I managed to fix them by setting up variables.
I’m still seeing this error when I try to see the executions list:
Sometimes when I go to the workflow list, I get this window that never finishes loading:
Sometimes I see this when I F5:
Then made a new workflow, added a webhook JavaScript to resolve Fibonacci problem (to test capacity) and a response webhook with the Fibonacci solution.
It works when I request it from the webhook-test but not when I try to run it from the production webhook: I get these two errors:
    "code": 0,
    "message": "There was a problem executing the workflow"
or
    "code": 404,
    "message": "The requested webhook \"POST 23435f7b-1345-4df7-acf1-109b2cf930b6\" is not registered.",
    "hint": "The workflow must be active for a production URL to run successfully. You can activate the workflow using the toggle in the top-right of the editor. Note that unlike test URL calls, production URL calls aren't shown on the canvas (only in the executions list)"
I togged a few times the “Active” toggle to make sure something didn’t go up correctly…
Any ideas??
Thanks!
  • n8n version: 1.7.1
  • Database (default: SQLite): PostgressDB
  • n8n EXECUTIONS_PROCESS setting (default: own, main): queue
  • Running n8n via (Docker, npm, n8n cloud, desktop app): ecs aws
HI @yukyo :wave: This sounds like a configuration problem - can you post your Docker compose file as well as any logs you have? :eyes:
