RE:How (is it possible?) to duplicate n8n workflows using n8n workflows?
I have workflows that I would like to have a workflow/s that -
  1. Duplicates the workflow
  2. Creates a new webhook and changes one variable
  3. Renames the new work flows.
The flow/s that do the duplication would likely be triggered by a webhook.
Is you had the same problem and you fixed it please give suggestions!
This is a copy of How (is it possible?) to duplicate n8n workflows using n8n workflows?
n8n has a rest API that you can use to retrieve and create workflows. So you would need to get the workflow you want to duplicate, modify what you need to modify and then post that to the API again.
Hey @BramKn
That is what I’m trying to do (I think)
But I’m not sure how to set up the create:workflow node.
what error do you get?
Its not about the error I don`t know how to set it up correctly
and when I try to use the exact Json code I got (from the workflow, just copy and paste it)
