n8n 1.29.1
Sometimes this error is happening on my redis node
Does anyone know what connection limitation is accepted by redis for x amount of time?
What is its software limitation?
n8n 1.29.1
Hey @admdiegolima,
I suspect you opened more connections than your redis instance can handle, Have you checked the redis logs to see if they show any errors?
There were many recordings in redis that did not expire, I deleted them and set them to expire after x seconds, this seems to have resolved it
