Redis Node Connection Timeout
I’m using the Redis Node to implement rate limiting on my n8n workflow, this used to work without problems until recently, I started to experience a lot of workflow errors with the node displaying a connection timeout.
The problem is eratic, sometimes the workflow runs smoothly, and at other times not. The Redis DB is hosted on Redis Cloud, where I have a reasonable paid subscription. There are no errors recorded in the Redis logs and when I look at the n8n run history, I don’t see anything to suggest too many requests are being sent to the server.
I am using the simplest implementation to increment a key with a timeout.
Hoping that somebody here might have had a similar experience and may be able to offer some support. Another user describes a similar issue here - however unlike them, the database doesn’t contain unexpired keys (and I’m not sure why that would cause a connection timeout anyway).
How can I verify if this is a problem with n8n or my workflow, or with my Redis configuration?
n8n version
1.37.0 (Cloud)
Stack trace
Error: Connection timeout at Socket.<anonymous> (/usr/local/lib/node_modules/n8n/node_modules/@redis/client/dist/lib/client/socket.js:178:124) at Object.onceWrapper (node:events:631:28) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at Socket._onTimeout (node:net:598:8) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
Hey @Felix_is_stuck,
It sounds like we are timing out when connecting to the redis instance, Where are you running it?
I suspect a good possible starting point would be if we actually had a timeout option for the connection that could be increased.
