Respond to Webhook output does not display the Response Body message in n8n
Hi everyone,
I recently tested how to access n8n webhooks from Tiledesk. This was quite straightforward and the data received from Tiledesk was correctly displayed in the JSON output of the Webhook node.
However, the webhook response message configured in the Respond to Webhook node wasn’t displayed in the corresponding JSON output. I’m wondering if the result output should also contain: {“make_status”:“Hello Julia!”}.
The workflow itself works perfectly.
P.S. I’m running n8n in Docker, version 1.24.1.
Hey @yulia,
The Respond to Webhook node just outputs the input items, I do wonder if maybe we should look at changing this though.
Hey @Jon, I see, thanks a lot for the info! Maybe it would be useful for debugging issues.
