Running n8n locally in docker telegram webhook problem
hello there i am new to n8n and i am not a programmer . so i am trying to run n8n locally in docker but i am having some problem running telegram trigger gives the following error
Show Details
Telegram Trigger1: Bad Request: bad webhook: An HTTPS URL must be provided for web-hook
as far as work flow goes i only used telegrams on message tiger entered token from bot father try testing it out but shows the above error. thanks for your help in advance
hello @kira
That means you should set up the https (via reverse proxy) and public domain. If you have no experience in that, it is better to use cloud n8n.
That is true but i just want to run it once every week or when i am using my own machine thats was appealing for me when it comes to n8n i could autome some worke flows that i need done localy . Cheekd bunch of tutorials but none worked like ngrok, local tunnel, none are actually free or wont work or dont have documents that noobs can follow along.
Well… the easiest one would be a docker compose with traefik or ngrok
Thanks for the reply again. I alrady set up the ngrok . But couldn’t find the doker compose file . I installed n8n searched the image using doker desktop and pull. Which was with out coding where would i find the dokercompose.yaml file . Or do i have to create it ? Thanks again.
What OS do you have? Windows/Mac?
you should create the docker compose file somewhere and then do some shell commands to build it (it’s not that hard)
