I am running n8n with docker, I want to run a production server with SSL and basic auth on it dor that I first need to set up the docker config which is listed on some of the other posts but I am really struggling with swarm and treafic can anyone help me out?
Try to finish some kind of tutorial in the next hours. But it will be using docker-compose.
It is probably not the best tutorial ever but it should hopefully help anyway. It can be found now in the docs here:
