The idea is:
Saving executions without (or only at defined nodes) data.
My use case:
I have some workflows that run a lot of data, which i do not care that it has at one node many data, but the saving of the execution does not make sense, as i save the data anyway as a csv and with all the data in the execution i can not simply open the saved execution as it always tries to load all of the saved data as well.
If we could save a execution, that only contains the times, like how long did which node need and when was it started and so on, i could make a better picture of the effeciency of the workflow.
Additionaly it would be a nice to have, to be able to save data at specific nodes, for debugging reasons for example.
Also it would hel to not fill up the postgres DB as quickly.
I could help, but i am not that experienced in javascript.
