Schemas in Supabase node other than public (http custom settings ? )
Hello,
In the Supabase node, only the public schema is available.
See this post:
I’ve followed this
But it does not allow to change the schema, so I tried, but failed to customize the http node here
I’m not even sure of the config to set (tried import curl directly but didn’t get the url, at least, correctly.
Is there some advanced exemple of such configurations ? Would the Supabae API would allow the expected schemas in that case ?
Obviously a “select schema” box in the native Supabase node would be perfect, but I suppose I’ll have other problems with different services in the future so might be interesting to understand it a bit better…
Thanks for your support !
Hi @NiKoolass
Thanks for reporting this! Just had a play around and it indeed looks like we’re only fetching the public schemas.
Will raise an internal ticket and turn this into a feature request. Should be a low-hanging fruit to implement :slight_smile:
Hi @ria, where can we track the status of this new feature?
Hello,
After digging a bit more, I see that the issue is just that the public schema is hardcoded by default.
If I use the memory chat node, and choose Postgres it works perfectly fine.
In that case, if no schema is provided, the public schema is used by default, but if you specify it hardcoded:
my_schema.my_table
Or with an expression:
{{ $json.values.object[0].value.schema }}.{{ $json.values.object[0].value.table }}
It works !
So I guess it’s something quite easy to fix ?
Thanks for considering this update :slight_smile:
The Supabase node brings the conditionnal filters with expressions, and that can be quite interesting for me.
@ria Do we have any updates on this? It still the same, we cannot acces to another schema
We’re almost ready to release this.. Sorry it’s been taking so long!
Here’s the PR to follow
Good news!!
Thanks for ur reply
New version n8n@1.90.0 got released which includes the GitHub PR 13339.
Does not work for me, on 1.97.1. Only public and graphql_public are allowed
Hi @Gyro, did you expose your custom schemas to the API?
See here for reference:
