Searching developer: n8n node for IBM DB2 and IBM Informix
Hi,
I am looking for a developer who can build a custom node for IBM DB2 using this node.js package: https://www.npmjs.com/package/ibm_db
The custom node should run on n8n with Docker.
Greetings,
Daniel
Hello Daniel,
:waving_hand::waving_hand::waving_hand: Hi @dpat :waving_hand::waving_hand::waving_hand:
That sounds like an exciting project! Building a custom node for IBM DB2 using the ibm_db Node.js package to run on n8n with Docker is feasible. Here’s a tailored solution to get you started:
A custom n8n node can be developed to integrate with IBM DB2 by leveraging the ibm_db package, which provides asynchronous/synchronous interfaces for Node.js to connect to IBM DB2 and Informix databases. Since you want it to run on n8n with Docker, the node will need to be packaged appropriately with the necessary dependencies and configurations.
I would like to discuss in more detail over chat.
If you are interested in me, please click HERE
Thank you.
Patrick King
