So, The issue I am recseiving is I am getting a connection lost error in the top right of our two different self hosted platforms. I have done everything I can think of it fix. I am going crazy.
We are using: ALB → FARGATE → RDS
Right now, It seems the frontend is actinv very randomly and just not well compared ot our cloud model. Another strange thing it does is sometimes the excution will not go right away. Like. The exection button is spinning but you dont see the workflow moving from one box to another if that makes sense.
I have also seen when the frontend is running. Its a 50 50 if the exucetion is truely running or not.
I have configured 1CPU and 2GB of ram on our ECS Fargate. I have not tried adding more but its not running that hard
The ALB/ECS/RDS are all in the same VPC and is and not needing to peer or anything like that.
I am so lost at this point that I just need ideas
Dont have Any
Dont have Any
- n8n version: 2.4.4
- Database (default: SQLite): Postgress (RDS)
- n8n EXECUTIONS_PROCESS setting (default: own, main): own
- Running n8n via (Docker, npm, n8n cloud, desktop app): Docker in ECS Fargate
- Operating system: ECS
