I keep getting an error message (maybe because it’s a localhost?) in n8n while trying to connect to my Google Calendar.
For context, I am hosting using Render. I’m kind of new to all of these and may have skipped some steps, if you have any questions please ask. Thank you!
What about that other option - deploy latest reference, what does that do?
Note: only make changes it if you know what they are, like I said I never used render, so you must make sure you understand the options before you click on them. I bear no responsibility.
Welp, I tried running it and it wipes my data hahaha, it’s fine though, I haven’t gotten far with it. Seems like I haven’t input the storage for my data yet, and I might need to work on that first.
Please do let us know after you are done, doing so will help then next person who has the same question as you did.
Yes, investing in persistent storage (at least some) would be great, but you can also export and re-import both your workflows and credentials, if you have set some up already.
So, this is all because I was doing it wrong. If you want to try doing n8n using Render. Try doing it through this tutorial and there should be no problem in deploying anything.
