Send an Array in SQL Query agent possible?
If i send a query in postgres module like that my function work
SELECT valider_reservation_multi(
72, – id_client
ARRAY[1,2], – id_tables (tableau PostgreSQL)
‘2025-02-14’, – date_service
‘13:00:00’, – heure
‘midi’, – service
1, – sous_service
10, – nombre_personnes
NULL – extra_info
Now if i try to do it in SQL tool for AI : { {{ $fromAI(“id_table”)}} }
it always seems to add like that :
N8N adds quotes that break the array: ‘ARRAY[1’,‘2]’ instead of ARRAY[1,2].
**n8n version:**1.78
**Database (default: SQLite):**postgres
**n8n EXECUTIONS_PROCESS setting (default: own, main):**default
**Running n8n via (Docker, npm, n8n cloud, desktop app):**docker with coolify
**Operating system:**debian 12
There’s currently no official support to send arrays using $fromAI function.
But you can use a workaround:
1. Configure the AI Tool to return either a single number or a comma-separated string:
$fromAI("user_ids","User IDs (comma-separated for multiple users, e.g., '3,4,5')", "string")
2. Use a Code node to turn the data into an array:
:backhand_index_pointing_right: If my reply answers your question, please remember to mark it as a solution.
Thanks ,Thats why i couldnt do it !! it was impossible
Yeah hahah does that solve your issue?
At least for now… until the team implements the array feature
