I’m trying to set up task runners in external mode in AWS ECS.
If I set N8N_RUNNERS_MODE=external, then the code nodes will timeout.
If I set N8N_RUNNERS_MODE=internal, then the code nodes will execute successfully. (but I want external mode)
Here is my ECS task definition:
"family": "n8n-worker-dev",
"networkMode": "awsvpc",
"taskRoleArn": "...",
"executionRoleArn": "...",
"requiresCompatibilities": ["FARGATE"],
"cpu": "2048",
"memory": "4096",
"containerDefinitions": [
"name": "n8n-worker",
"image": "docker.n8n.io/n8nio/n8n:1.122.2",
"command": ["worker"],
"portMappings": [
"containerPort": 5678,
"hostPort": 5678,
"protocol": "tcp"
"environment": [
{ "name": "N8N_ENCRYPTION_KEY", "value": "..." },
{ "name": "N8N_CONCURRENCY_PRODUCTION_LIMIT", "value": "200" },
{ "name": "N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS", "value": "true" },
{ "name": "N8N_RUNNERS_ENABLED", "value": "true" },
{ "name": "N8N_RUNNERS_MODE", "value": "external" },
{ "name": "N8N_RUNNERS_AUTH_TOKEN", "value": "..." },
{ "name": "N8N_RUNNERS_BROKER_LISTEN_ADDRESS", "value": "0.0.0.0" },
{ "name": "N8N_NATIVE_PYTHON_RUNNER", "value": "false" },
{ "name": "OFFLOAD_MANUAL_EXECUTIONS_TO_WORKERS", "value": "true" },
{ "name": "DB_TYPE", "value": "postgresdb" },
{ "name": "DB_POSTGRESDB_DATABASE", "value": "n8n" },
{ "name": "DB_POSTGRESDB_HOST", "value": "..." },
{ "name": "DB_POSTGRESDB_PORT", "value": "5432" },
{ "name": "DB_POSTGRESDB_USER", "value": "..." },
{ "name": "DB_POSTGRESDB_PASSWORD", "value": "..." },
{ "name": "DB_POSTGRESDB_SCHEMA", "value": "public" },
{ "name": "DB_POSTGRESDB_SSL_ENABLED", "value": "true" },
{ "name": "DB_POSTGRESDB_SSL_REJECT_UNAUTHORIZED", "value": "false" },
{ "name": "QUEUE_BULL_REDIS_HOST", "value": "..." },
{ "name": "QUEUE_BULL_REDIS_PORT", "value": "..." },
{ "name": "QUEUE_BULL_REDIS_TLS", "value": "..." },
{ "name": "GENERIC_TIMEZONE", "value": "America/Los_Angeles" },
{ "name": "N8N_LOG_LEVEL", "value": "debug" }
"healthCheck": {
"command": [ "CMD-SHELL", "wget -qO- http://localhost:5678/healthz || exit 1" ],
"interval": 5,
"timeout": 3,
"retries": 2
"essential": true,
"user": "root",
"logConfiguration": {
"logDriver": "awslogs",
"options": {
"awslogs-create-group": "true",
"awslogs-group": "/ecs/n8n-workers",
"awslogs-region": "us-east-1",
"awslogs-stream-prefix": "ecs",
"awslogs-multiline-pattern": "^\\S.*"
"name": "n8n-code-runners",
"image": "192984850590.dkr.ecr.us-east-1.amazonaws.com/n8n-runners-custom:latest-dev",
"essential": true,
"dependsOn": [
"containerName": "n8n-worker",
"condition": "HEALTHY"
"environment": [
{ "name": "N8N_RUNNERS_TASK_BROKER_URI", "value": "http://n8n-worker:5679" },
"options": {
"awslogs-group": "/ecs/n8n-code-runners",
In the UI I get this message:
Task request timed out after 60 seconds
Your Code node task was not matched to a runner within the timeout period. This indicates that the task runner is currently down, or not ready, or at capacity, so it cannot service your task.If you are repeatedly executing Code nodes with long-running tasks across your instance, please space them apart to give the runner time to catch up. If this does not describe your use case, please open a GitHub issue or reach out to support.If needed, you can increase the timeout using the N8N_RUNNERS_TASK_REQUEST_TIMEOUT environment variable.
In the runner logs, I have only this:
Starting launcher's health check server at port 5680 [0m
[launcher:py] Starting launcher goroutine... [0m
[launcher:py] Waiting for task broker to be ready... [0m
[launcher:js] Starting launcher goroutine... [0m
[launcher:js] Waiting for task broker to be ready... [0m
In the worker node I have this:
n8n Task Broker ready on 0.0.0.0, port 5679
n8n worker is now ready
n8n worker server listening on port 5678
Worker started execution 3 (job 3)
Worker started execution 3 (job 3) {"scopes":["scaling"],"executionId":"3","workflowId":"bKHtVsTBU2PWyOvu","jobId":"3","file":"job-processor.js","function":"processJob"}
Execution ID 3 is a partial execution. {"executionId":"3","file":"manual-execution.service.js","function":"runManually"}
Workflow execution started {"workflowId":"bKHtVsTBU2PWyOvu","file":"logger-proxy.js","function":"exports.debug"}
Executing hook (hookFunctionsPush) {"executionId":"3","pushRef":"difxefr5ig","workflowId":"bKHtVsTBU2PWyOvu","file":"execution-lifecycle-hooks.js"}
Start executing node "Code in JavaScript" {"node":"Code in JavaScript","workflowId":"bKHtVsTBU2PWyOvu","file":"logger-proxy.js","function":"exports.debug"}
Executing hook on node "Code in JavaScript" (hookFunctionsPush) {"executionId":"3","pushRef":"difxefr5ig","workflowId":"bKHtVsTBU2PWyOvu","file":"execution-lifecycle-hooks.js"}
Running node "Code in JavaScript" started {"node":"Code in JavaScript","workflowId":"bKHtVsTBU2PWyOvu","file":"logger-proxy.js","function":"exports.debug"}
Published pubsub msg: relay-execution-lifecycle-event (executionStarted) {"scopes":["scaling","pubsub"],"msg":"relay-execution-lifecycle-event","channel":"n8n.commands","type":"executionStarted","executionId":"3","file":"publisher.service.js","function":"publishCommand"}
Published pubsub msg: relay-execution-lifecycle-event (nodeExecuteBefore) {"scopes":["scaling","pubsub"],"msg":"relay-execution-lifecycle-event","channel":"n8n.commands","type":"nodeExecuteBefore","executionId":"3","file":"publisher.service.js","function":"publishCommand"}
Error: Task request timed out
at ErrorReporter.wrap (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/errors/error-reporter.ts:242:37)
at ErrorReporter.error (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/errors/error-reporter.ts:228:25)
at LocalTaskRequester.requestExpired (/usr/local/lib/node_modules/n8n/src/task-runners/task-managers/task-requester.ts:296:22)
at LocalTaskRequester.onMessage (/usr/local/lib/node_modules/n8n/src/task-runners/task-managers/task-requester.ts:259:10)
at TaskBroker.handleRequestTimeout (/usr/local/lib/node_modules/n8n/src/task-runners/task-broker/task-broker.service.ts:115:50)
at Timeout.<anonymous> (/usr/local/lib/node_modules/n8n/src/task-runners/task-broker/task-broker.service.ts:102:9)
at listOnTimeout (node:internal/timers:588:17)
at processTimers (node:internal/timers:523:7)
"file": "error-reporter.js",
"function": "defaultReport"
- n8n version: 1.122.2
- Database (default: SQLite): postgresdb
- Running n8n via (Docker, npm, n8n cloud, desktop app): AWS ECS
- Operating system:
