Can the execution IDs be exposed in the side panel? Only showing the date/time can be very confusing if you have multiple executions that run within seconds (or milliseconds) of one another:
Why do you need to see the execution id on the panel, if you can simply enter the execution id in the address bar to jump into it?
I guess it’s mainly because beginner users may not necessarily know that address bar shortcut right away.
As well as they won’t need to know about the execution ID at all. Unless they start to use the error workflow ![]()
Maybe the docs should be clearer on how to deal with executions, though.
